rookosu
Question, got a neck in that was spec'd for gotoh/grover tuner ream. Have some Gotoh magnum tuners I am throwing in the holes.
I haven't screwed/fastened them in the headstock yet, but just test fitting them, they are not snug fit at all. All other warmoth necks I've had you needed to give it a lil' push to even get the post through the hole, then assemble.
These can rotate 360 degrees without touching the interior of the ream hole. Is that fine? Once you screw in the set screw, then tighten the two assembly (top and bottom of headstock) pcs together and tighten them in place is that fine?
Or is this a concern because you need that tension fit to help with tuning stability?
