Strat Matt
Hey guys,
Hopefully one of you has experience with repairing amplifiers and is willing to help me out.
I recently purchased a non-working 1966-67 Gibson GA-5t amp for cheap in order to practice fixing such things. I've modded my own amps (grounded plug, new filter caps) with success, but never a full repair. Anyways, on to the problem...
Here is a schematic for reference: http://www.0rigami.com/gg/ga-5t_skylark_white-panel__back_qual6.jpg
The only change is I've added a three prong power cord and removed the death cap (C15).
Symptoms: No guitar signal passes through to speaker. I still get a wobble when turning up the trem. I measure voltage within spec everywhere except at pin 5 of V2 (300vdc) and at pin 7 of V2 (0vdc). Also all resistors measure within spec.
I believe the problem lies with V2. I have tried a few different tubes in there with the same results. I also removed the cathode bypass capacitor to check if it was faulty, but experienced no change in any measurements. There could also be a problem with the Phase inverter transformer. I fear this possibility the most as it would be expensive and invasive to replace. I also don't have an accurate method of testing transformers.
Any help is greatly appreciated. I know this isn't an amp or electronics forum, but I've been a member for several years and I know the collective knowledge here is expansive.
Thank you,
-Matt
Thank you,
-Matt
