Gammit10 said:
...the jack won't fit into the jack route. It's supposed to be 3/4" but it's a few mm too snug.
Yeah, a typical 1/4" phone jack...
...wants a 7/8" hole to fit into, which is 3mm larger in diameter than the 3/4" hole you specified.
If you're
very lucky, have lived well and been kind to the unfortunate, you'll be able to bend those connection tabs closer to the main jack body, maybe file on the fiberglass insulating wafers a bit to reduce overall jack diameter, and fit that unit into a 3/4" hole. But, I wouldn't hold my breath while trying pull that off - you might suffocate.
Another thing you can do is get a short bit of 3/4" wood dowel, glue it into that jack hole so the end is flush with the outside of your body, then re-drill the output jack hole to 7/8".
Finally, the least fun way out of this is to try sanding the inside diameter of your existing hole until you have enough clearance to get that jack in. Or, perhaps a combination of the first suggestion and this one.
And before you even ask, no, I don't know why Warmoth offers 1/2" and 3/4" output jack holes for some bodies. The only thing they're good for is disappointing unwary users when they finally realize that the only output jack hole that works is 7/8". Unless, of course, you order the rear-mount water hose fitting on your control cavity cover and need a drain hole. But, hard as it is to believe,
not one customer has ever done that!
Besides, the 7/8" hole would work better for that, too. :laughing7:
