I'm about half way through an oil finish on my mahogany body. What I want is a satin finish, but so far with every new coat of tru-oil I put on it is getting shinier and shinier. If I was after a high gloss finish - this would be great, but I'm not! This is what I have done so far:
4 Coats of Birchwood Casey Sealer & Grain filler (sanded with 400 grit in-between each)
3 coats of Tru-oil so far (sanded with 600 then 1000 grit in-between each coat)
I was then intending to use 0000 steel wool to try and give it a stain finish.
My question is what should I do next - a few more coats of tru , then scuff it up with steel wool. Should I then wax it??
Any advice for a good satin finish would be appreciated - thanks
