Patrick from Davis said:I use teflon insulated shielded wire, surplus stuff from an airplane supply house. While it does not shield the cavity, it does shield the signal. It is quite easy to use, and there is not shorting problems, which I have had before.
KaiserSoze said:I put two dream 90s in a Les Paul knockoff and they are very quiet. The case around the pickup seems to make a difference. Just make sure everything is properly grounded.
