![S6300088-1-1.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300088-1-1.jpg&hash=9dc913da56b58540713673fd9ececf63)
30.5" scale, swamp ash, maple/ebony neck, Schaller bridge and tuners, "High-C" tenor tuning - E A D G C. I thought I might have to tune up a whole step to F# B E A D because of the scale, but it's working fine as is with D'Addario Chromes. I guess you might get away with lower action with tighter strings... I inset the top strap button with a 1/2" brad point drill bit. After seeing enough of those on custom guitars and PRS's the ordinary, Strat-type strap attachment with the sides of the button hanging off into space started looking barbaric, cheap and under-engineered:
![S6300090-1.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300090-1.jpg&hash=74965a1b313e7a3a510175f02a90250f)
Hey! Where are the side position dots?!? Oh crap - HERE are the side position dots:
![S6300095.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300095.jpg&hash=5fb818393c071fe604249937094a5f12)
(3/32" nickel/silver rod)
Hey! Where are the front position marker dots? OH CRAP! Here they are:
![S6300096.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300096.jpg&hash=722aaa04759d0dfccfd66571bc3af7c4)
(3/16" nickel silver rod - I also have some 1/4" red acrylic rod on the way, I'm not sure which way the dots will go...)
Hey! These body shapes sure look similar!
![S6300091.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300091.jpg&hash=2a366041f15b80e459893903b1342a7f)
Hey! These string retainers sure look similar!
![S6300092.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300092.jpg&hash=d50529ef35ce5edb6fa46c334cacc1f5)
The maple/ebony, swamp ash, Schaller bridge & tuners brothers:
![S6300093-1.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300093-1.jpg&hash=41e951f4e2cfffaff476a11067064778)
The short-scale brothers:
![S6300094-1.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300094-1.jpg&hash=87e63b9d8747313a840b5decfb2dafb4)
I have some cool little brass gears I was gonna use as knobs, but the more I look at it the more I think such a simple, classy babe needs just some basic amber Les Paul bell knobs.
![S6300098.jpg](/proxy.php?image=http%3A%2F%2Fi100.photobucket.com%2Falbums%2Fm1%2Fstubhead%2FS6300098.jpg&hash=262b7a5d83c196237082a583d9b44811)
(also pictured is the Delrin AF sheet I cut the nut from, and some 1/8" brass stock I'm gonna use to make it a real brass nut when I recover from the build burn... might upgrade the string guide too.)
This thing is an absolute gas to play, but of course the intonation requires absolute attention - it's got 28 "frets" so the highest note is an E5, equivalent to the E note at the 12th fret of the high E string on a guitar. I have to do some organized intonation drilling, at least an hour a day till February or March I figure, then I'll decide whether to put in a preamp or not. I had Warmoth rout the hole for a double battery box, but I'm already getting the midrangey, 600Mhz - 2K Les Paulish tone I wanted, so maybe I'll just have to use the 18-volt battery hole as a condom dispenser or something. :icon_biggrin:
