Hi all, new member. Decided to do my first build out of mainly Warmoth parts, so this seems like a good place to keep a diary of it.
Here's the basic spec:
Telecaster body, with strat contours and heel contour. Rear routed, as I've got a lot of electrics to jam into it.
Tele neck, with V-shaped back profile and compound radius. TUSQ XL nut, standard Gotoh tuners.
So far, so normal. The thing that I'm really motivated by is an idea I've got for the pickup switching, based around 3 Duncan P-rails humbuckers, which gives a slightly ludicrous 144 switching options. There's an independent three way switch for each pickup, giving the p-rails options of humbucker, P90 and single coil, plus a "bridge on" control on a push-pull volume pot.
It's going to take me a while to get together, but in the meantime, here's some pictures:
Body and neck straight out of the box:
First draft of wiring diagram (would appreciate feedback on this):
