Cagey
Mythical Status
Zaman said:You will get weaker tone on a thin neck as opposed to a thick neck. That is fact and not myth. Your neck plays a HUGE role in your tone.
You will absolutely get hand fatigue due to the overall lack of support a thin neck offers your hand. When you're playing on a thick neck, you are forced to grip the entire neck and have more resting contact between your hand and the neck itself. On a thin neck its just the tip of your thumb. That is not myth.
Ultimately, there are no set rules as human anatomy doesn't get stamped out on a conveyor belt. If a thin neck is comfortable for you then its the right neck for you. If a thicker neck is your cup of tea then good for you.
I agree that the physical design of a neck has something to do with the tone you'll get out of the guitar. That only makes sense for a wide variety of obvious reasons.
I don't see where a neck has ever "supported" my hand anywhere. I don't hang my fretting hand off the neck by my thumb, or try to fret with my thumb, so where is the neck "supporting" anything? Worst case is my hand is supporting the neck, at which point I realize I picked up somebody else's guitar with a neck that's heavier than the body or has poorly located strap hangers. Best case is the neck stays where it's put because the instrument is balanced, so support isn't an issue.
I also agree that all humans are different, claims from the terminally philosophical notwithstanding <grin>
