Heres some very usable and Cool Mod Ideas......got these from Rothstein Guitars........
http://www.guitar-mod.com/rg_diag_strat.html
http://www.guitar-mod.com/rg_dialatap_11.html ........11 Sound H-S-S Strat with Dial-A-Tap
http://www.guitar-mod.com/wiring/dial_a_tap.gif.......• H-S-S STRAT WITH NO-LOAD DIAL-A-TAP -
Same as above, only without the neck-on switch
http://www.guitar-mod.com/wiring/lonestar_strat.gif .......• LONESTAR STRAT -
5 way super switch is used to split the coil of the humbucker when in position 2 as well as to assign a separate tone control to the bridge pickup (with a .022 uf cap) and another tone control for the single coils (.047 uf).
http://www.guitar-mod.com/wiring/blender.gif .......STRAT WITH BLENDER POT -
5 way switch with master volume, master tone and blender pot (works best with a "no-load" blender).
A blender pot allows you to blend (mix) the neck pickup or the bridge pickup into the signal which will provide you with 2 extra sounds, namely: bridge/neck (very Tele like) as well as all 3 pickups on simultaneously. If the 5-way is in the neck position, it blends in the bridge pickup. If the 5-way is in the bridge position it blends in the neck pickup. You can dial in as much or as little as you want. For example, one of Lindy Fralin’s favorite ways to use blender wiring is add just a little bit of the neck pickup to warm up the bridge pickup.
Blender pots ideally should be “no-load” pots (see above) so when the pot is on 10 the pot is completely removed from the circuit, and therefore not loading the circuit in any way (think “true bypass”).
Here is a summary of how the blender works in relation to the 5 way selector switch:
POSITION
ORIGINAL PICKUP COMBO
BLENDER FUNCTION
RESULTING PICKUP COMBO
1
Bridge
Blends in neck pickup
Bridge/Neck
2
Bridge/Middle
Bridge/Middle/Neck
3
Middle
Non-functional
Middle
4
Middle/Neck
Blends in bridge pickup
Bridge/Middle/Neck
5
Neck
Neck/Bridge
