I don't think you can go wrong with any of the listed pickups, but I prefer Nordstrand's. Had bad luck with DiMarzio's about 15-20 years ago, and it left a mark. Not saying that means anything now, but... I would get a bunch of ideas of the sound you'd like, artists and song examples, and talk to the guys at Best Bass Gear. As Greywolf indicated, they have quite the selection, but they will steer you to the one that sounds most like what you are after. I have had very good luck with them in the past. I had an issue where an manufacturer had not clearly defining something, it happened to be only for a very specific application, so they replaced the part with one that would work. Then they called me later to ask how it was working. Bottom line is they are interested in doing things right. If you give them some clues, they help you figure it out.
