B
back2thefutre
Do you have to use steel strings with steel frets, and nickel strings with nickel frets? Can you mix them, steel with nickel? :icon_scratch:
back2thefutre said:Do you have to use steel strings with steel frets, and nickel strings with nickel frets? Can you mix them, steel with nickel? :icon_scratch:
Laptopkoen said:Do you mean how they wear and tear on the frets? Nickel frets just .. crumble ..
it doesn't matter which two stringsknucklehead G said:Cut two strings off and put some flatwounds on there, and never change your strings again.
Schlieren said:it doesn't matter which two stringsknucklehead G said:Cut two strings off and put some flatwounds on there, and never change your strings again.
or you can cut one string twice, and replace it with two strings
