HI, I recently ordered a gecko 6 string and had it routed for a hipshot A style and p4 pickup shape.
Now that I am trying to nail down what pickups to order I am a bit confused as on Warmoth's site it states that the Hipshot bridge should have 16.5 mm spacing but I can only find Hipshot A style bridges with 17mm or higher. Also I am considering either Nordstrand or Bartolinis and as best I can tell they are not made to work best with that small of a spacing. So my questions are will a Hipshot A style bridge that has 18mm spacing work with the bridge routing that Warmoth does, also will that work with the gecko neck taper. Or do I have to look for pickups that are more suited for smaller spacing. In this thread
http://www.unofficialwarmoth.com/index.php?topic=8056.0 there is a beautiful Gecko 6 string the has Nordstand pickups and a Hipshot bridge so I assume this can be done but I am not sure if I made a mistake having the routing for the bridge done before researching more.
Any thoughts from those with experience would be much apreciated
Thanks
Thanks
