String Retainers and how many?
Mor Paul
They are going to therapy as we speak.
What kind of help are we talking about? One should do it. What headstock?
ZGOZZ
Just one on the e and the b string right?
Patrick from Davis
Play the strings in open chords, like a G chord or an E chord and listen to the high strings.  If it sounds like they are not sitting down well and ringing true then put your first finger over the e, then the e and b, then the e b and g...  Figure out which ones are ringing, or buzzing or whatever the term is for this, and add a retainer to those strings.  By putting your finger over the string behind the nut it will pressure the string into the nut, like a retainer.  It is not always required, but the e and b needed it on my neck.
dbw
Some Squiers use two.  One should be enough if the nut is set up well.
K
kreig
I'm sure there will be one poster here that will make this their pet rocket science project, we're all waiting . . . :laughing8:
SkuttleFunk
it all depends on which headstock - angled headstocks don't require any, a 3+3 headstock would most likely need just on on the middle two strings but could use two if you weren't getting enough pressure on the next outward pair, a 4 in-line uses one on the D & G strings (same with a 4+1)
for bass, I definitely prefer the Hipshot version above the Fender style button
easy enough, eh?
all the best,
R
