Stratocaster control cavity
jwp
I don't have a Strat available to check this myself....
Is the control cavity of a top rout Strat large enough to fit four standard-size pots and a three-way blade switch or three-way LP-style toggle without additional body routing? Effectively, the question is whether it's possible to fit LP-style controls into a top rout Strat's control cavity.
At the moment, I'm not tpo concerned with the aesthetics of this, just whether it'd fit.
If you use mini pots I think you could just about squeeze all that in, although it'd be tight and I'm not sure that you could have them in the LP configuration.
Thank you, Jumble. Probably what I should do is go get a $50-$75 guitar from a pawn shop and try it.
