I've been experimenting and once the 5-way rotary switch arrives I'll show you what I've put together - a tone switch that produces only useful, and distinctly different, tones. Each position will sound different and good. I think it's a better approach even than the 16-position tonestyler because all the futzing around to dial in the right sounds has already been done - the tones that are available will be only the tones I want to have there. The problem is 'popping' when changing between caps.
