Ive found that the sound certain humbuckers make when split is usefull. Ive tried playing guitars that have mini switches and push pull pots to split humbuckers and it has always seemed cumbersome, to me at least.
I read about arcade style killswitches that are the right size and would be easy to push real quick while your playing to split a humbucker while not being in the way. Only problem is that the arcade style switches that ive found are only momentary switches and I dont even know if wiring them to split a humbucker is possible. I would like to find an arcade style button switch that you would push and let go of the switch and it would split the humbucker, then push and let go of the button to go back to full humbucking mode. Ive seen something sort of like it in the Suhr Guthrie Govan signature model blower button, but it just goes to the bridge pickup in full without a cap or anything and the button seems kind of small. I was wondering if any of you had tried this and or if know where to source a push push on-off arcade style switch.
I usually end up smacking the volume knob on a strat when I strum and turn down the volume on accident so I usually just reposition the volume knob on a normal strat and get rid of one of the tone knobs. I was thinking that it would be about the perfect place for a button coil splitter that could be easily accessed quickly, and since it is so low to the body I would not hit it on accident. Im hoping it would look something like this but with a arcade style button to split the neck and bridge humbuckers at the same time instead of a black metal volume knob that i used to represent an arcade style button.
Here are some red arcade style killswitches on a Gibson Buckethead signature les paul that look like they would be the perfect size for the job, though they are only momentary switches.
[youtube=425,350]http://www.youtube.com/watch?v=A2ettpeAYWg[/youtube]
