GuitarEC said:I ended up changing that wiring diagram (switching positions 1 and 3 - being that the bridge pick-up along would be the more used, I wanted it on the end). I've got a copy of it somewhere on my PC - let me know if you're still interested...
Also, I ended up getting my rotary switch from Stewart-MacDonald. But the luthier who put the whole thing together for me needed to countersink the control holes in the cavity for the thing to come through. And also the clearance needed by the switch limited it placement to that bottom control hole. If you want your elsewhere, I would recommend you have your body shipped without the control holes pre-drilled.
Just my observations,
Eric "GuitarEC"
P.S. If you want a larger version of the picture, let me know and I'll send you the original.
Hi, thanks for the info
