rightintheface
so, i've finished my black/white double f-hole thinline (pics very soon, waiting for my camera off my girl). it's routed for TOM/stop, and i noticed when painting that the neck "angle" is extremely shallow. i'm thinking; 1 degree or so :-\.
so she's all strung up, truss rod adjusted nearly sraight (got a bit worried as it was rather difficult to turn, didn't wanna damage it so i backed off a little). did the intonation, the TOM is sitting as low as it can physically get (and the inserts are seated flush with the route, so they can't go any further), and still my action at the 12th fret is nearly triple what my other warmoth (recessed tom) has.
i'm thinking of a neck shim, anyone got any good hints/tips? i've already searched through the forum but couldn't find anything concrete. i've never done shimming before. i'm ok at woodworking etc etc but am a little wary about shimming. but then, i'd rather learn to do it myself, i've done everything on this build without help from my luthier. it's all a learning exp i guess.... :tard:
could it also be nut height? its a W installed graphtec, i haven't adjusted it as yet (no nut files), but i checked it with the "hold down the the string in between 2nd/3rd fret" and it seems to be pretty good there. generally i wanna HALVE the action. should i put a shim made of wood, or card or something, maybe a little more than i need, and adjust the bridge as per normal?
oh, and it sounds BITCHING btw :guitaristgif: :guitaristgif: :guitaristgif:. the rosewood/macassar ebony standard thin is absolutley GORGEOUS. i'm not not sure which i like more, it or my wenge/eb boatneck :icon_scratch:
PICS VERY SOON, MAYBE ON MY IPHONE
