Jack_H
Has anyone installed a recessed TOM bridge? I have installed one TOM post and it was quite a tight fit. The hole for the other one has a small hole for ground wire. The body is swamp ash so it's not really hard but I am worried that driving the post over the wire might get it cut off, and I know that once the post is installed it's not coming out. Maybe I should cut a little groove so the wire won't stick out too much?
And should I remove the chrome plating where the ground wire contacts the post?
