Danuda said:
The blue tape does not seem to pull up the paint like the green did so so far so good. I am almost done with the paint (for the second time :icon_tongue
so I will post pictures when I am done. Then all I have left to do is the clear coat.
I wrote a pile of process monitoring software for a high-end "tape" manufacturer some years back, and have since forgotten more about "tape" than most people would ever want to know. But, I do remember a few things.
For one, they get sorta pissed if you call it "tape". It's not. It's a "coated film", and the film can come in a wide variety of forms, as can the adhesives they coat them with. I know, it's silly, but that's the industry. Same way if you talk to anyone from GE's Lamp division, or Phillips, or Ozram. There are no such things as "light bulbs". They're
lamps, you silly goose! <grin>
More to the point, if you asked them for "masking tape", they'd ask what you're masking and what you're masking against before they'd recommend anything. Most people call paper tape "masking tape", and it may even be labelled that way, but there's no clue on the package as to it's intended use. Masking tape for painting purposes shouldn't allow any bleed underneath it, and it shouldn't have any residual VOCs such as toluene in the adhesive that could dissolve or otherwise affect the substrate. Finally, it should release easily even after some time has passed.
What they're selling now as painter's masking tape is colored blue to differentiate it from adhesive paper tape, because the market has been so corrupted. Theoretically, you should be able to trust that stuff to be suitable for effectively masking painted surfaces, as opposed to the other stuff where all bets are off. Not that there's no such thing as proper beige paper masking tape, but it has become too hard to be sure that's what you're buying and if you're wrong, you can end up with poor or even destructive results.
Danuda said:
On that note. Does anyone know about how much clear coat I should put down? I have 1 full can of Deft but will I need to put more on than that? How many will I need do you think?
As has been mentioned, More's law applies: Some is good, More's better. Too much is just right <grin>
Be aware that there's a lot less coating material in the can than it seems. For one, there's a helluva lotta propellant, and B, there's a lotta reducer. In what looks like a 22oz can, there's probably only 2 or 3 ounces of actual solids. About half or more of that is going to be overspray that never touches what you're trying to coat. So, buy more than you need. Better to have too much and not need it, than to need it and not have it.
