bpmorton777
hey
I had some tear-out while drilling my side jack.a a large arrow head shaped chunk came out. I drilled a 1/2 inch hole and was planning on using a deep panel jack because i did not have a drill bit larger than 1/2 and anything larger would not have fit my drill. I was able to save a bit of the torn out wood but not all. Should i have a few ideas about how to fix this. I could have somebody with a bigger drill make the hole bigger (could be more tear-out then) or I could try to fix the mess i made with wood putty and glue. What id really rather do is see if i could just mount a deep panel jack on one of those jack plates. Does anybody know if this is possible.
Brian
Brian
