I read some topics on Shellac as a sealer recently, and a salesguy at the local woodcraft even advised me to use it as a grain filler.
I know that it won't make a smooth surface, but that is not what I am after either.
so can somebody give a bit of a step by step on using Shellac? (how many coats, applyt with brush or cloth, sanding betseen coats, etc)
also, should I use dewaxed or regular.
I am planning to use the amber shellac or a mixture of clear and shellac, so I can skip staining. does this work?
what (wipe on) finish would work well on top of shellac? I want somthing somewhat semi glossy (as opposed to tung and danish oil)
is there an easy method in combination with the above to make the flame pop out in the maple?
