C
Cowbell Fever!
Dr. Seb, my Burmese Leroy thinks you have a lot of ball*, I mean fortitude!
Spud said:Dr. Seb, my Burmese Leroy thinks you have a lot of ball*, I mean fortitude!
The progress you're making is very encouraging, but I would think you may need to do a fret level if there's any unevenness or to restore fall-away, etc.DrSeb said:The primary concern is whether the 3rd session will finally put a proper forward bow and rectify the uneven slope at the heel.
Triple Jim said:The progress you're making is very encouraging, but I would think you may need to do a fret level if there's any unevenness or to restore fall-away, etc.DrSeb said:The primary concern is whether the 3rd session will finally put a proper forward bow and rectify the uneven slope at the heel.
rick2 said:I use mineral oil on ebony to keep it from drying out. What did you use?.
That sounds like a very good plan.DrSeb said:Agreed. If it ends up being usable I fully anticipate badly needing a fret leveling given the amount of trauma it's been subjected to over the past week alone.
I would probably wait a while though to let it settle in once strung up.
Spud said:Did we learn a lesson? Steaming wood is how they bend wood to make barrels.
The art of cooperage.Spud said:Did we learn a lesson? Steaming wood is how they bend wood to make barrels.
And cooperage and its most famous industry which it supplies is a blessing! (disclaimer, not all barrel contents are created equal.)TBurst Std said:The art of cooperage.Spud said:Did we learn a lesson? Steaming wood is how they bend wood to make barrels.
Cagey said:As long as the fretboard isn't twisted, you can always bake it again to build in more/less relief. A known straightedge (a machinist-grade tool, not just a ruler - they can be pricey, so check ebay first before throwing $100 at Starrett or StewMac) and a fret rocker will reveal a twist.
