BigSteve22
So, I've been noticing lately that my Tele has required a little more effort to play. Checked the bridge saddles, and all's locked in place just as I left it the last time I checked. Checked the action at the 12th fret on the low E string and found it to be somewhere between .050" and .060", which is NOT where it was the last time I checked. (It was set between .040" and .050".)
As the saddles had not moved, I checked the relief using a Starrett machinist's scale/straight edge, (1/8" thick, non flexing steel, machined flat) and a feeler gauge, and discovered that instead of the .008" I had set it for, it now measured .014"! Took my time, and several iterations of de-tune, adjust, (using the side adjuster), re-tune, wait, remeasure, and got it set back where it was. Took a total of about 1-3/4 turns of the screw, and all's back to normal now.
My Strat neck, also a modern construction, standard thin profile neck, also required readjusting after 6-8 months of playing. I would also note that the Strat neck has been rock solid ever since, and that I expect the Tele to follow suit.
Now, I'm not complaining by any means. I'm used to seasonal truss rod adjustments on other instruments. It's just as a note to owners of Warmoth modern construction necks, which have a reputation for stability. If things seem a little different after playing for a while, and your saddles haven't moved, check the relief.
