set in neck question?
northlane
is it possible to change a set in neck with another and does warmoth make necks that are suitable for a set in entry(not a bolt on)?
northlane said:
is it possible to change a set in neck with another...
I suppose it's possible, but it's highly unlikely. Installing a set neck usually involves some corrective shaping to get it right, which means it's more or less married to that body.
northlane said:
...and does warmoth make necks that are suitable for a set in entry(not a bolt on)?
No. I don't think anybody does. If you have one that's broken, it may be possible to glue it back together. If it's just that the frets are worn, they can usually be refurbished or replaced. If the instrument is important to you, then sometimes even the fretboard can be replaced. But, it's not a trivial task so for what it would likely cost you, you could probably replace the instrument.
