Hi there, I'm on to finish my first Warmoth-Strat and I'm stuck with the electronics-part.
Pickups:
HSH, the single-coil in middle-position is also a humbucker.
1 Master volume with push/pull. I want this to switch the neck humbucker from series to parallel.
1 Master tone with push/pull. I want this to split both neck and bridge.
1 Dummy tone with push/pull. I want this to add bridge to every switch position.
I know how to achieve the last 2 options but switching the neck from series to parallel doesn't work for some reason.
Further questioning if this idea is possible at all?
Best,
reery
Pickups:
Best,
reery
