Screws for no pick guard
gouzos
I'm still not sure what screws to use with my no pickguard strat body.
I found these diMarzio p-bass pickup screws that measure about 30mm or 1.18".
You think these are right?
jackthehack
The non-P90 (P90s take much longer screws) that Warmoth sells are .75"; those DiMarzio's should work, but I would measure the depth of the PU route and ensure that they aren't long enough to get the bottom of the body, don't think they will, but I'd recommend double checking. ALWAYS drill pilot holes for PU direct to wood mounting, I will guarantee that you will either strip the Phillips or snap off the head if you don't; use a 1/16" drill bit for the pilot holes.
