I am using Duplicolor acrylic lacquer to paint the body of my guitar. The primer is a BIN as recommended by Guitar Ranch. I sanded that down with 320 until smooth and for good measure even did a wet sand using 600. Disappointingly, I am still seeing scratches under the black gloss paint coat. At this point I have not applied any clear coat, and post this for any guidance as to how to best proceed. Should I sand it all back, and if so using what grit? Will additional paint coats take care of the problem? Clear coats?
BTW, when I did my headstock I sanded between the paint and clear using 600 wet and similarly CREATED scratches that showed up under the clear. I sanded this all back and second time around did no sanding before applying the clear (paint was very smooth). Second time came out much better. Thoughts?
Thanks in advance for all input.
