As long as you have the tuner hole reamed correctly, you can install the tuner and tighten the nut down just a bit and the pins will make dents in the wood you can use as a guide to drill the holes for them with.
I bought one of these on Tonar's suggestion after some initial reservations about the price - just make your life easy and get one. I've already used it a couple of times and it works with my Schallers just fine. The thing is built well and should last a lifetime.
