jplev22
Hi,
I have a flamed maple/alder body coming soon which I plan to finish using stain and clear coat.
The product I planned using in order:
[list type=decimal]
[*]Colortone powdered grain filler
[*]ColorTone Liquid Stain
[*]Sander sealer?
[*]Nason® SelectClear™ 498-00™ 2K Urethane Multi-Panel Clear
[/list]
I have used 2k Polyurethane directly over water-based dye before without issue. Maybe just luck?
Should I use a Sanding sealer or just use the first light coats of 2k poly as a sealer?
What sealer would you recommend under 2k Poly?
[list type=decimal]
[*]Sander sealer?
[/list]
