This is my first custom build so I'm trying to be extra extra careful on everything. I started out thinking I'd do a cheap parts caster, but after seeing my buddy's roasted maple neck, I knew I needed it. Started with an old MIM strat body. Anyways, that's beside the point.
Ordered everything and so far soldering and working on the body has been no trouble. But after reading horror stories of people cracking their roasted maple necks, I am being extra paranoid. I ordered the Gotoh vintage 11/32" tuners, and got the neck reamed at 11/32", but putting the bushings in is SUPER tight. I would definitely need a hammer or something to get them in there, but am very hesitant. I am told that they should go in by push of a thumb.
I guess my question is: should I take a light sandpaper and go around the ream holes until the bushings fit in with just hand pressure? As for the pilot holes for the tuner screws on the back: some videos show a pilot hole that is basically the inside width of the screw, with the teeth biting into the wood, and a countersink for the shank of the screw. The roasted maple say go a size bigger on all pilot holes. I'm guessing maybe go the entire width of the shank? Would it be better to go a bit bigger and have it held in by tension or wood glue in a worst case, rather than go too small and crack the head?
Thanks in advance!
Thanks in advance!
