supertruper1988
Also as an FYI, the Gotoh 510 in Charvel guitars has a shorter block. I am not sure if a standard block would stick out the back of a guitar if it was recesses into the top.
The stud spacing on the Wilkinson route and the 510 route is slightly different if I recall correctly.Does the semi recessed wilkinson route work with the 510 to provide more pull up range? Just a random thought on this after seeing this thread last week.
Indeed they are. I know that both bridges have a flat spot for some variation in studs but its not a huge range. Might be a "buy and try" situation hmmmmm.The stud spacing on the Wilkinson route and the 510 route is slightly different if I recall correctly.
"issue" is a loose term. The recessed Floyd thing started because Via wanted more pullup range compared to the standard top mounted floyd. "top mounted" was also a loose term and was a range from the bridge sitting on the body allowing for down-only dives to the Jackson/Charvel style where the floyd sat up off the body and had some pull up range. It also felt like a TOM bridge because the neck was angled relative to the top of the body to accomplish this.Maybe this is a hot take, but I've been a strat wielder for many many decades and I definitely pull up on the trem more than push down.
Do I understand that the Gotoh 510 has issues with this unless the route is recessed? I was planning on putting the 510 on my next strat build just to check it out, but not sure I want to if this is really the case...
locking saddles for more stability
They're pretty dang good-lookin' guitars. The pearlescent ice-cream-pink version is gorgeous, too.I so want one of these!!!!
They do now.Unless something has changed recently, Gotoh does not offer locking saddles for the 510.
@aarontunes Bring on the recessed route for the 510 please.
Thanks for the reply, at least I can order the 510 route and have a local luthier do more work to get it where I want (if needed).This likely won't happen. We've already looked into it. For more context check out this video:
They do now.
All the models with the 'LS' suffix.
The range is ridiculously low for pulls. You can pull maybe 1/2 step in most casesOut of interest, what is the pull up range of the current 510 route?
I'm only really looking for moderate to wide, above and below pitch vibrato.
Warmoth feature request:
Can the Gotoh 510 cavity be recessed? Images from Ibanez AZ shown with this type of cavity.
But why
just for the aesthetic?
Realistically, does someone going to pull back on one like a F to the Lloyd?
