krystalfire918
from a previous post in May I understand there may be dremelling required to make these bridges fit, I didn't realise how tight Warmoth's floyd route is - I assume it's not just a one off thing and that all their OFR routes are like that?
Did anyone actually drill out the holes for Gotoh trem, as they are not only wider and taller? I don't want any structural issues
I've seen and had guitars with floyd rose that couldn't pullup much due to a tight cavity which stops the trem block, I've even had the underside screw of the trem bar grind on the cavity, any users with Warmoth soloist and floyd rose recess can chime in? If I can pullup 7-8 semitones from open G string that's all I could ever want
The Gotoh's 43mm GHL-2 nut comes in a 15" radius, any issues if I just use a Floyd shelf as I want a 12" radius?
