Question Regarding Tuner Sizing
Nerdo
I recently ordered a neck from Warmoth:
Style: Stratocaster®
Construction: Vintage/Modern Construction
Orientation: Right Handed
Neck Wood: Roasted Maple
Fingerboard Wood: Indian Rosewood (Dark)
Nut Width: 1-11/16"
Back Shape: Wolfgang
Fret Size: SS6105 (Stainless)
Tuner Ream: Gotoh/Grover (13/32" 11/32")
Radius: 9.5-14" Compound
Scale: 25-1/2"
Fret #: 21
Pre-Cut Installed String Nut: GraphTech White TUSQ XL - Standard Nut
Inlays: Gold Pearloid Nightswan
Side Dots: White Side Dots
I'm not sure the tuners will fit, after reading a few other posts regarding tuner hole sizing. Can anyone confirm these tuners should fit or not?
Tuners:
Gotoh Magnum Lock-Trad 6-In-Line Tuners -
https://www.stewmac.com/parts-and-hardware/tuning-machines/solid-peghead-guitar-tuning-machines/gotoh-magnum-lock-trad-6-in-line-tuners.html
Thanks!
Sean
It looks like the part you're contemplating from StewMac depends on a straight-sided 10mm ream, while the standard "Gotoh-Grover" ream is step-sided, and slightly larger than 10.3mm in the wider dimension, and ~8.7mm in the narrower one.  If you use a reamer to widen the narrower dimension out, the part you're looking at will "fit", more or less, but there'll be a little wiggle in the fitment.  Once you torque down the ferrule nuts and install the anti-rotation screws on the back of the neck, any wiggle will probably be locked down, but if knowing you're 0.3mm out of a perfectly snug fit chaps your hide, you'd be better off selecting a different, more perfectly-sized part.
Thank you so much! I'm very new to the partscaster world, never tried to build one before; I probably should have asked this beforehand! It seems the forums are super helpful, and at this point I feel like I have read almost every thread on here, since the waiting is killing me! I don't mind reaming the holes to make them slightly larger, but if they're loose at all, that would make me nervous! Hopefully StewMac is good about returns!
I bought the same machine heads, but my neck order has the 13/32 “Planet Waves” tuner hole team. Is 1/100th of an inch too large going to be noticeable? Man I hope not!
If not, you can always hold onto them for your next build ;)
I've always liked dealing with StewMac (although their prices are a little ridiculous for some of the more common items). I did return something before when I realized I ordered the wrong size/type.  If you don't have their membership, you'd need to pay the return shipping cost, though (I don't buy enough from them to justify the $40/year).  For me, it was worth taking the extra hit because I wasn't going to find myself using that wrong piece.  No hassles.
