I'm a big fan of offsets, started on J-Bass... it was written in the stars that I'd build a Dinkycaster. So I did. Loved it. Decided to special order one and build from scratch.
Then I fell in love with a neck in the Showcase; you know the story.
This guy is a "forever" guitar, no doubt. Absolutely smitten.
Body Specs
Body Specs
- Construction Solid
- Core Wood Mahogany
- Lam Top Wood Swamp Ash
- Right / Left Handed Right-Handed
- Control Cavity Top Rout
- Multi Pickup Top Rout Universal Dinkycaster
- Jack Rout None
- Bridge Rout Type Tremolo
- Bridge Rout Vintage 6-Hole
- Mounting Holes Standard 4-Bolt
- Neck Pocket Shape Strat®
- Body Contours Forearm Contour, Tummy Cut, Custom Contoured Heel
- Binding and Edge Decorations Light Wood Laminate Accent Line
- Construction Vintage/Modern
- Shaft Wood Birdseye Maple
- Shaft Wood Upgrade Very High Grade
- Fretboard Wood Birdseye Maple
- Nut Width 1-11/16" (43mm) - Modern Medium
- Neck Back Profile Standard Thin
- Fretboard Radius 10" - 16" Compound
- Number of Frets 22
- Fret Size & Material SS6150 - Wide & Tall (Stainless)
- Tuner Hole Size Gotoh/Grover (13/32" - 11/32")
- Inlay Shape Standard Dots
- Inlay Material Black
- Side Dots Black Side Dots
- String Nut Standard Nut - GraphTech Black TUSQ XL
- Neck Heel Shape Strat® Shape
- Pickups and Electronics Fishman Fluence Scott LePage signature wired as Tim Henson signature
- Bridge Vega Tremolo, black
- Neck Mounting StewMac black neck ferrules, Philadelphia Luthier shorter gold screws
- Tuners Gotoh 510
- Strap Locks Schaller S-Lock
- Body Varathane Rustic Sage (oil), Genuine Oil (6 coats), light buff with steel wool
- Neck Tru-Oil (3 coats), light buff with steel wool. Lacquer headstock
