That was i was thinking also that qtr sawn canary might be brighter than a flat sawn piece.fdesalvo said:Most people say that canary is a bit warmer than maple. Maple itself is a bright and dense neck wood- many people think that qtr saw cuts of this wood are even brighter. In theory qtr sawn canary might simply be brighter than a flat sawn piece. I can't be certain, but it stands to reason. I personally love qtr sawn maple for its quick response, stability, and complex grain patterns. I'd love to see a nice piece of qtr sawn canary. It would be well worth taking a chance if this option is available, as qtr sawn wood is gorgeous in my mind.
So you say it IS possible to get a Quarter Sawn one piece canary neck then :cool01:fdesalvo said:You're getting me fired up! I've got a neck on its way haha. Can't wait! ccasion14:
Wyliee said:fdesalvo said:Most people say that canary is a bit warmer than maple. Maple itself is a bright and dense neck wood- many people think that qtr saw cuts of this wood are even brighter. In theory qtr sawn canary might simply be brighter than a flat sawn piece. I can't be certain, but it stands to reason. I personally love qtr sawn maple for its quick response, stability, and complex grain patterns. I'd love to see a nice piece of qtr sawn canary. It would be well worth taking a chance if this option is available, as qtr sawn wood is gorgeous in my mind.
I'm curious where this 'many people' comment comes from. Quartersawn maple is just flat sawn turned 90 degrees. Same species of wood.
fdesalvo said:Wyliee said:fdesalvo said:Most people say that canary is a bit warmer than maple. Maple itself is a bright and dense neck wood- many people think that qtr saw cuts of this wood are even brighter. In theory qtr sawn canary might simply be brighter than a flat sawn piece. I can't be certain, but it stands to reason. I personally love qtr sawn maple for its quick response, stability, and complex grain patterns. I'd love to see a nice piece of qtr sawn canary. It would be well worth taking a chance if this option is available, as qtr sawn wood is gorgeous in my mind.
When I was researching which cut of maple I wanted for my neck, the information that is readily and abundantly available on the internet says that qtr sawn maple has a brighter tone. This is the consensus- I'm sure opinions vary. Same species, different orientation of the grain. Who knows..
Wyliee said:fdesalvo said:Wyliee said:fdesalvo said:Most people say that canary is a bit warmer than maple. Maple itself is a bright and dense neck wood- many people think that qtr saw cuts of this wood are even brighter. In theory qtr sawn canary might simply be brighter than a flat sawn piece. I can't be certain, but it stands to reason. I personally love qtr sawn maple for its quick response, stability, and complex grain patterns. I'd love to see a nice piece of qtr sawn canary. It would be well worth taking a chance if this option is available, as qtr sawn wood is gorgeous in my mind.
Sources please. And is this anecdotal information? Heard it from a friend of a friend?
Based on several years on the phones and thousands of customers (along with a good portion of QC work), I have not found quartersawn maple to be brighter than flatsawn. Totally up to you what you want, but that's my first hand experience.
Well i am not a fan of his guitar designs but Paul Reed Smith knows a hell of lot about the resonance properties of wood!Dan025 said:ozzie pete posted this in a thread about "scientific tone testing."
http://www.youtube.com/v/QSbjCfK5Iq8
check out the tap test on brazilian rosewood at 1:42
pretty convincing that direction makes some difference, maybe not alot, on one hand the string vibrates as far as i can tell in an oblong pattern, it doesn't just move up and down or side to side so i'll bet there is some combination of different harmonics going through it, maybe one or the other is dominant depending on direction, i dont know. i'm not opposed to the idea but IMO the difference will be small. and i certainly wont argue that there is no difference
line6man said:Wyliee said:fdesalvo said:Most people say that canary is a bit warmer than maple. Maple itself is a bright and dense neck wood- many people think that qtr saw cuts of this wood are even brighter. In theory qtr sawn canary might simply be brighter than a flat sawn piece. I can't be certain, but it stands to reason. I personally love qtr sawn maple for its quick response, stability, and complex grain patterns. I'd love to see a nice piece of qtr sawn canary. It would be well worth taking a chance if this option is available, as qtr sawn wood is gorgeous in my mind.
Yep, I'm curious as well.
Quartersawn Maple is not some magically piece of wood, it's just Maple that's been cut at a different angle. No difference.
Or perhaps this has something to do with the neck vibrating differently because the string tension goes against the structure of the wood differently? :dontknow:
