Tony Ounsworth
If you're not careful I'll give you some more to do...
Jumble Jumble said:That's very, very gratifying coming from you, Kevin. Thank you.Cagey said:Mr. Jumble is clearly very good at what he does.
Study the nuances that makes your Charvel feel right (implies the use of calipers) and apply as much of those nuances as reasonably possible to your Warmoth neck. Obviously you'll have to narrow things up to create a very slight almost invisible bulge along the slab while maintaining necessary board space for the strings. In other words, it's a laundry list of tricks and it's all as close as a hair on cat's behind.john_p_wi said:^^^^^ This
The squared off vertical edge slab of a fret board is what I have noticed the most of the Warmoth necks that I have purchased compared to, in particular, my early 80's USA Charvel which has an oval profile that "just feels right". Hard to modify a finished neck to roll the whole fret board, but will try to on an unfinished neck that I have.
I guess it depends on your level of expectation
