One coil from each of two humbuckers, connected together in series, with a capacitor in parallel with one of the coils. Dangled croc clips out of the guitar to test/decide on the capacitor value and settled on .01uF.
Well this is a really good idea, if I understand it you've basically put one coil to work as a hum-canceller, but the biggest part of the tone will come through as a single? Kinda like the dummy coil pioneered by Alembic, or the low-output coil hidden inside a "noiseless single" type pickup. But... but... (see buttbutt note below).
One thing I know for sure is that the Lawrence L500's have a really good tone when split to single coils, And I have been using the blade switch on them for... dang, a long time. Most humbuckers sound pretty weak by themselves when they're dumped down to a single coil, and that sound works best if they're both engaged. And if
It's such a good sound I'm going to dedicate another position on the 5-way to the same thing, but with a different capacitor value.
you should chase it around for sure. Of course, if any one coil can be a "main" and another the dummy, you've got twelve possible variants, before you even GET to different cap values... :toothy10: but the world needs it's mad scientists, if only so the villagers can run around with pitchforks and torches now and then.
It always strikes me as comical when somebody bangs together a Warmoth or mods some Epiphone to conclude with something like:
"The choice of a SD '59 paired with a JB at the bridge proved to be the best of all possible worlds!"
Umm... actually, to "prove to be the best" you
have to try ALL the 72,000 other possibilities available from Seymour Duncan. Then start in on the DiMarzio's. :laughing11:
One of the reasons I want to wire two possibilities on a switch is because the Buttbutt Factor, which states:
THINGS THAT SOUND GREAT IN YOUR BEDROOM SOUND AWFUL WHEN PLAYING WITH OTHERS, AND THINGS THAT SOUND GREAT IN A BAND SOUND AWFUL IN YOUR BEDROOM.
Even if you could bypass the razzing that would happen if you showed up to play with little bits of cardboard and wires sticking out, and even if you could avoid bumping into them, when you stop the band practice and say,
"O.K. - that was my solo through the 300k Gibson pot wired with a paper-in-oil .033 capacitor! Now let's play it all over again, only this time I'm gonna use this foil cap with..." try that will all six capacitors, then announce
"O.K., now we're going to try each capacitor with this next potentiometer, an early-60's Allen Bradley 485K... don't worry, we got six down, only forty-two left to go!"
Oh goody. Sounding bad within a band context is surely the second-biggest impediment most guitarists will face, besides just plain sucking. But at least you are
trying some things, which is more than most people can say. The whole reason I'm designing this thing with removable pickup plates is so that I
can have four or five of them with different combinations of single coils and humbuckers. I'm sure it will end up with a P-rails eventually; and I'm sure it will end up with an Alumitone eventually; and I'm sure it will end up with a Troubled Tele eventually; there's bound to be a Fernandez Sustainer in there sometime, mebbe EMG's, etc., etc., etc.
Again with the pitchforks, I think it was Chuckles Darwin who said that 99% of all spontaneous mutations were bad ones, or, at least, being able to whistle "Dixie" backwards was no help with the sabre-toothed tigers. But if that first brave,
hongry Cro-Magnon fellow hadn't trapped, killed, butchered and roasted a slowpoke Neanderthal, we'd probably ALL still be running around oongah-boongahing in caves somewhere.
