So,
Coffee (the guitar)
is assembled and I have played with it for a while and I am
extremely happy with it, overall.
The
wiring (described in post #
18 in this thread)
worked perfectly, which of course could be assumed as it was provided by
@stratamania
Here are the switch positions, as a refresher:
- ”Solo/Blower Switch": In this position the pickup would not be altered in any way, producing the "full sound"
- "Solo/Rhythm": In this position there would be only a fixed 500K resistance (or similar) to "tame the tone" a bit
- ”Rhythm/Clean": In this position I would be able to use a Volume knob, a Tone knob, and a "Spin-a-Split" knob
Position 3 works great, I get a wide variety of tones (beyond what
@aarontunes means by it
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
), and Pos 2 sounds pretty close (with a
0022 µf capacitor) to Pos3 with everything on 10. So I am very happy with those two positions.
However, Pos1, the "blower switch", although it added some volume and depth to the tone, it did not really make that much of a difference, so I have a
new idea for what it should be used for. But
I would - again - need some help verifying that is it doable and/or how it should be done.
Basically, I would like
Pos1 it to sound like
Pos3 with everything on 10, e
xcept the Tone, which would be on (around) 5. I would use that as a bluesy tone for solos. Using the "description" above, it would look something like this (only Pos1 is changed):
- ”Bluesy Solo": In this position the pickup would sound as if the Volume would be on 10, but the Tone on 5. But just like Pos2, totally independent of the Volume and Tone (or S-a-S) controls
I have a couple of ideas of how it could be done (at least in theory), but I would need some help verifying them (as well as better ideas):
- Simulating the tone: I surfed the entire Net again
and found a couple of (somewhat) related postings (this and this ), but it looked to me like trying to figure out the correct recistors/caps/whatever would be very complicated and time-consuming. Now, if it actually is pretty simple to figure out, I would like to go that route.
- Adding another Tone control: If option 1 turns out to be too complicated, I was wondering if I could hide another tone control in the guitar cavity (not drilling a hole in the guitar for a knob), set it on 5, and then somehow connect Pos1 through that tone control and then to the output jack? This would be nice, as I could fine-tune tone the tone control to the exact tone I want, and then just leave it there.
What do the experts here say about those two options, from a doability point of view? Could it be done, which one would be easier? How could it be done? Other solutions?
Again, many thanks in advance for your help!
And yes, I am sure some people will wonder "but, why?", but let´s just say that this is my guitar, so I decide what I want to do with it
