pulling a broken screw =[
Dietrich
I was putting on a string tree when the screw gave.  I have about 1/16th in. hanging out of the wood.  Tried some small needle-nose pliers with no luck.  Any words here?
Damn.  Should've just bought a guitar.
GoDrex
do a search  - I've seen at least two threads about this kind of thing since I've been here (not all that long).
Don't let that screw get you too down. I had a lot of problems on my build and it still worked out great in the end.
Dietrich
OK man, yeah, good advice.  I search way more than anything, but I was pretty upset that I may have an unwanted hole in a 2K guitar.
As per a suggestion found here, I think I am going to order a couple of these:
http://tltools.com/tlt/product.asp?mscssid=33JP6A4MRTFV9GQFV07280C52N1F7TCF "Unscrewums."
Can someone give me an easy answer for the size I need?  Has anyone found success with this?  The guy who commented said he did it with teak and it worked very well.
TroubledTreble
Bummer, Most likely the 1/16" will work fine. Did you predrill that hole? It can be intimidating to put a drill on a nice new neck but it sure does help prevent these things from happening.
Dietrich
Update:
Just got off the phone with the guy from TLTools.com.  Very nice fellow--we spoke for about ten minutes.  He took my name, and when my order comes across in a few minutes, he is going to put some different sizes of the "unscrew-em" in the shipment for me so that I can get the exact size.  I'm hoping that since the hole was too small to begin with, I may be lucky enough to not have a hole that's too big for another screw of the same size.  Either way, I am doing a custom headstock decal and could probably arrange to cover the spot up easily, so there are options.  Will update here in a week or so when the piece comes in.
DocNrock
Actually, it was good advice.  There have been two threads on this board for exactly this problem.
G
guitlouie
by my count this is the sixth, and in the last one I posted a link to all the others before it.
-CB-
Talked to Frank Ford about those un-screw-ums yesterday.  He hand' heard of 'em but was gonna give 'em a try.
