Cagey said:"Pro" series necks have a dual-acting truss rod with a side adjuster mechanism, which adds a few ounces of weight/mass to the neck. I've never noticed that they were any brighter than other styles, but from a purely theoretical standpoint, they probably should be. Still, you'll get a lot more effect by changing the wood species, profile and scale length than you will from using that truss rod system.
For example, a short-scale Maple neck with a boatneck profile is going to be very bright, while a long scale Mahogany neck with a wizard profile is gonna sound dead in comparison, regardless of the truss rod.
On the plus side, those "Pro" style necks stay the way you set them. Temperature and humidity won't make them move around like most necks will. Pretty much a "set it and forget it" setup.
line6man said:I've never understood why people always feel the need to ask if whatever they are interested in buying is best for metal. It arises so frequently on some forums that it has become a joke. It's never any other genre. Only metal.
Why wouldn't a pro neck be just fine for any style of music?
dwillen said:What about a burds eye maple neck with a alder or basswood body? Do you think that it would be too bright with a fair amount of gain and hot pickups (21k)? Also thanks for the reply.
dwillen said:Cagey said:"Pro" series necks have a dual-acting truss rod with a side adjuster mechanism, which adds a few ounces of weight/mass to the neck. I've never noticed that they were any brighter than other styles, but from a purely theoretical standpoint, they probably should be. Still, you'll get a lot more effect by changing the wood species, profile and scale length than you will from using that truss rod system.
Cagey said:line6man said:I've never understood why people always feel the need to ask if whatever they are interested in buying is best for metal. It arises so frequently on some forums that it has become a joke. It's never any other genre. Only metal.
I've never understood it, either, but mainly because most metal players are running industrial strength military grade super-hot humbuckers into power boosters into Rats into Tube Screamers into Muff Pies into the highest gain Marshalls extant with the most wattage. Maybe some modulation effects in the loop just for fun. There's so little left of the guitar it's not even worth talking about.
Cagey said:dwillen said:What about a burds eye maple neck with a alder or basswood body? Do you think that it would be too bright with a fair amount of gain and hot pickups (21k)? Also thanks for the reply.
Bird's Eye Maple sounds like Maple, oddly enough. It's just prettier. Body wood can make a difference, but on the list of things that will change your tonal character, the body wood is down a ways on the list. Alder is a good choice, Basswood is a bit fragile and will show wear much more quickly. Neither has a very interesting grain so they're usually finished in solid colors.
line6man said:dwillen said:Cagey said:"Pro" series necks have a dual-acting truss rod with a side adjuster mechanism, which adds a few ounces of weight/mass to the neck. I've never noticed that they were any brighter than other styles, but from a purely theoretical standpoint, they probably should be. Still, you'll get a lot more effect by changing the wood species, profile and scale length than you will from using that truss rod system.
Bright is subjective, but there sure do seem to be a lot of people with that combo that seem perfectly happy with it. Remember that you can roll down your tone control when you want to take the edge off. This is especially true if you are playing through a lot of distortion. Very seldom can the nuances of wood be discerned when you are behind a wall of distortion.
Note that hot pickups in general tend to sound darker. If you overwind, you lose treble. If that's not good enough, try lower value pots to shift the resonant frequency downward. And if all else fails, a high capacitance on your tone control can transform even the sharpest ice pick into a puddle of mud. So you should have no problem at all finding a happy middle ground.
dwillen said:Cagey said:dwillen said:What about a burds eye maple neck with a alder or basswood body? Do you think that it would be too bright with a fair amount of gain and hot pickups (21k)? Also thanks for the reply.
Yeah, I was thinking of maybe doing a Camphor burl top![]()
