Cagey
Mythical Status
mullyman said:Good advice except for the "hotter the better" part. You'll want to stay in the 30-40watt range. You run the risk of burning things up using anything hotter. I know a guy that uses a 90w iron but he's been trained professionally through ESP guitars and doesn't take a whole lot of time holding the iron onto the parts. You can ruin pots with an iron that is too hot.
MULLY
Oddly enough, you run a greater risk of overheating things by using too light an iron, or too fine a tip. You have to leave the iron on the part too long to get it hot enough to flow solder properly, and heat conducts through things to places you may not want it to be. A hotter iron allows you to get on and off the part very quickly, so only the area you're soldering gets hot.
But, there's a limit - you get much above 40 watts for most electrical work, and even being on the part for a short period can get dangerous. Most "gun" type soldering irons are no good for electrical work. They get far too hot.
Not recommended
Actually, I don't know what those are good for. They're too light for plumbing or bodywork, and too heavy for electrical. But, they've been around forever. Maybe if you were building old-fashioned transformers or something....
