Planet waves jack installation ?
I was wondering if I needed a jack plate (argh which I did not order...) or if I could screw the body of the jack in the wood, in the hole, like the telecaster I did before....
Curious, that product is on the Planet Waves site, but no install sheet or anything. From just looking at the picture it would appear that you would need to install it through a jack plate.
Definitely needs a jack plate. Either Warmoth's "football", "square", or "recessed" - depending on your rout.
Yes, I think I'm *§*/ed....... did not ordered the plate, and won't make such an order from belgium ;-)
I'll have to find such a piece locally...
This should probably be more clear on the warmoth website, some specific pieces that require other pieces should probably be mentioned ...
anyway, my bad.. I'll find a solution.
thxs guys
Olivier.
