whitebison66
A local chain store was having their annual factory blowout, and I got hold of a Boogie Accelerator pedal (originally for the Revolver rotating speaker) for HK$300 (about US$35).
The Boogie is a CC (continuous controller) with a single jack in the front, and an LED on the side, but the basic aluminum housing is exactly like the Ernie Ball, with the side-mounted switch, no doubt made in the same factory.
It's black, too!
I want to turn it into a volume pedal. I dismounted the front, and the input plate (with Mesa/Boogie) was just a cover behind which was the 5-hole plate in much heavier stock.
I figure I need to swap out the pot; it's marked
KA1041R32
100K LT
TYPE K
PEC
MADE in CANADA
But it is a 3-lug pot, so I may just try it and see if it works; I don't much care for the idea of messing with the string and spring for the pedal...
Any idea what I can use the switch for, and how to wire it?
Any suggestions/advice would be very welcome, since I have never done something like this.
Thanks!
It's black, too!
KA1041R32
100K LT
TYPE K
PEC
MADE in CANADA
Thanks!
