LooseCannon
Hey guys, i'm new here so I searched and read everything I could find on these but still have some questions:
1. I've read the warmoth installed nuts still need some work since the slots are too high and not wide enough for a 0.10 set, how much work do preslotted Graphtech nuts requier? Since I'll need a tech to do some work on the warmoth nut anyway, I could save some money if i'll get the Graphtech nut instead.
2. I'm also considering the Eearvana warmoth installed corian nut, i've read some people say it makes a huge difference and some say it barely makes a difference so I guess i'll get the same responses regarding the intonation improvment. What I would like to know is if it would requiere some work on it as well like the standard nut, and is working on it any different than on standard nuts? Also how strong is corian? Does it wear fast? Is it smooth enough or does it cause some binding?
3. Regarding string trees, which type do you recommend? The roller or the barrel? Or maybe the Graphtech ones?
4. Assuming i'm stringing the guitar the best and most correct way do I really need locking tuners? And do staggered tuners really eliminate the need for string trees? I've read that some of them aren't low enough and you still need them.
Thanks in advance
Thanks in advance
