Due to the banker saying "you already have one custom guitar!" I've resulted to building a budget tele from GFS.
I received the body yesterday, it's in great shape, the blue pearl looks awesome. There are only a couple things wrong with it, which are easily fixable.
If you look at the string through holes, the D and G string holes are not aligned properly, like the guy drilling the holes used a hand drill and fell asleep in the middle of drilling the holes. Not a biggie, for a $75 body I don't expect perfection and can easily fix this by just filing the holes some to the left or right and make sure the strings aren't mooshed up against the body too much.
The second issue is that the holes drilled for the neck screws are a little off, basically if I put a plate on it, it's tilted at an angle some, should I be worried? My head tells me not really.
Also got a neck from them and one question I do have is what is the best way to drill the holes for the bolts? My thought was to clamp it on there, install the both E strings and line them up and then by hand marking the holes with the drill bit and then unclamp and drill. If there is a better way please share.
Thanks folks!
Thanks folks!
