[/quote]
can you elaborate or give me some suggestions?? Thanks
[/quote]
A can per day... one can in one day. How about one can in six weeks? or eight? Let it dry a good week or even two between coats. This is especially true of rattle-can lacquer which has more solvent so it "flows" better from the spray-bomb. Aerosol lacquer also has added flowout and anti haze and stuff... you need to let this dry longer than spray gun grade lacquer. THIN coats dry better. THICK coats take forever, and dont get as hard and tough as they should be. Spray a coat so that it gets "just wet", or think of it as a step beyond "dusting". Then let it go... put it away to dry and dont go back for two weeks. This is ESPECIALLY true of the coats you apply later on, because the solvent seeps into, and swells the finish UNDER it too. THIN is the way to go.
And, unless you waste the lacquer, you can probably get by with 2 cans of it, possibly 3, but remember - you're not leveling the grain in the finish. That must be level and smooth FIRST, then when you apply the finish, all you are leveling is the finish, not the wood texture. Hence, you dont need a finish that is thick. You just need one that is thick enough to level and provide a little durability - very thin that is.
[/quote]
Thank you. It make sence to now. The coatings I did yesterday were very light...dusting as you stated. It will let this dry a good week or two. Thank god the humidity is gone here in Philly!!
This is certainly an adjustment for me. I am so used to keeping a careful eye on automotive paint flash times and checking the "tack" of a test panel every 15-20 minutes this seems like well....watching paint dry!!!!!!!! If you let automotive go too long, the subsequent coats will not stick.
