LeftySteve
Hi,just a few questions from a total wiring beginner about soldering irons,wiring etc..etc.
1.Which size soldering iron would you guys recommend for wiring pots,pickups and jack sockets etc + what size tip/s
2.What gauge and type of wire do you use for connecting up pots to out put jack,toggle switches etc,and which type and gauge of wire do you use for grounding everything.
3.I understand you use rosin core solder for electrical soldering but I have read this can give off fumes which if inhaled can irritate your lungs(only asking due to having mild asthma).And if this is so is there any alternative or do I just have to wear a mask when soldering.
4.What gauge solder do you use for soldering guitar electrics.
I know some of these questions might sound dumb but I am a total beginner to wiring and soldering so wanted to be sure of what I needed before I purchase anything.Once I know what I need I will purchase everything and then I can practice soldering on some old pots I have before attempting my first warmoth build or upgrading pickups in some of my other guitars.
Any help most appreciated.
Thanks guys.
Thanks guys.
