New warmoth baritone build
WarmothRules
About 15 years ago I had a warmoth build that was a cheap squire body and a reverse KWS neck tuned in B standard. I played it in my technical death metal band and it was amazing but with some major flaws. The nut was never cut properly because I didn’t know anything about that and the saddles were un slotted ones on an ultra cheap 6 screw vintage trem. Since I was trem picking true 16th notes between 220-240 bpm I use to push the strings to locations on the saddles that matched what my hand wanted to do naturally. This made for some really clean accurate trem picking. The problem was since the guitar’s nut wasn’t cut properly and the strings just laid on the unslotted saddles pushed off to the sides the tuning stability was horrendous. I could play one song before I would have to push the strings back to where I liked them on the saddles and retune the guitar. I only sold that guitar because of its tuning instability. Between then and today I’ve tried many guitars and they were ok but still not exactly what I wanted for this band. The current guitar I’m using for these songs is an agile baritone 28 5/8 scale. Same as the warmoth baritone scale. The thing I dislike the most about this guitar is it’s kind of dark sounding. Not because of the pickups but because of the construction. It’s a tune o Matic bridge. It’s not bright and snappy. I love 28 5/8 scale because I can use thinner strings in B. When it’s fender scale you have to use pretty thick strings to get good tension in B.
So the intention with this new build is to have baritone scale, a bright snappy tone coming from a maple fender headstock baritone warmoth neck, and adjustable saddles side to side from a schaller 475 bridge so I can mimic my early setup. I’m tired of black on black so in my order I have a white pick guard coming. I had one of these squire bullet bodies in the past and thought the stock pickup sounded amazing! It’s very bright and clear. Almost like a single coil. If I don’t like it this time I’ll be putting on the white pick guard and putting in a dimarzio dominion pickup I have laying around. The baritone neck I ordered will have gold frets. I’ve had stainless steel frets before and didn’t like them. They felt weird. I know gold is hard but slightly softer than SS so I should be happy with it. Will add pics when the neck comes and add pics during the process of the build.
Still needs string trees, slight truss rod adjust and possibly moving the bridge closer to the neck. The saddles are very far forward and some strings are still a little flat intonation wise. Love stock the squire bullet humbucker!
The leading edge of the bridge plate ought to be in a similar position as the original bridge you had on there.
Thanks for pointing that out. I was hoping it would intonate properly using one of the pre existing holes from the old bridge to mount the new bridge. All the strings are flat at the 12 fret with the saddles are moved all the way forward. so I will be moving the bridge either towards touching the pickguard or back about a 1/16 of an inch. I also got a white pickguard for it which I’ll probably be putting on. The new pickguard has one volume in the tone 1 position. I do bump the volume on this pickguard by accident occasionally while picking. The new pickguard is white. Black on black is boring. It’s still a work in progress.
Thanks for pointing that out. I was hoping it would intonate properly using one of the pre existing holes from the old bridge to mount the new bridge. All the strings are flat at the 12 fret with the saddles move all the way forward. so I will be moving the bridge either the pick guard or back about a 1/16 of an inch. I also got a white pickguard for it which I’ll probably be putting on. The new pickguard had one volume in the tone 1 position. I do bump the volume on this pickguard by accident occasionally while picking
@WarmothRules the pre-existing screw holes are in the incorrect place for the bridge that you are fitting. Follow the advice I gave earlier.
I was going to put the bridge in the location i
It’s going to the proper location irregardless of this conversation.
Just trying to point you in the direction of where it needs to go so it will intonate etc. You are free to do you, of course.
The bridge has been placed in the proper location and intonated
