BigSteve22 said:
Brother, when you restart this project, I'll be here waiting to see how it turns out.
Still patiently waiting
Well i'm back. Sort of! And the progress is rolling. The neck all finnished: Burnished and oiled (it is "boiled lind-seed" in english, right), and the peghead is yellow, as the guitar body. I also had a good friend with luthier skills to do some necessary fretwork, so its all brand-new feel. Good thing to have the fairly small area of the peghead to play with, when getting into the spray-painting-n-wetsanding-n-polishing thing. It turned out pretty much as expected/hoped for.
Right now i am wetsanding the body with 400 grit, to follow is sanding in some steps down to 4000 (maybe its overkill, 2000 is enough(?), but the store carried 4000 so i thought "why not"...), and then polishing. Hopefully i will be happy with how it turns out, trying to aim for some "good enough" result.
It was hard to get here, i've seen comments about swamp ash being a bit of a challenge to work with, and i do agree. First i used grain filler on bare wood (i think i followed the instructions from stewmac correctly, though some might recommend a layer of paint/primer first?), then level sand. repeat. I actually used the whole can of grainfiller. then i started the spray-painting process. A few layers of white first, and more level sanding (which turned out necessary). Then layers of yellow, more levelsanding, and then finally a few layers of clearcoat. And... now im here wet-sanding, as said
I also got a new cool red pick-guard, and two single coils (from oil city pickups), which together with the old OBL 900XL will make a HSS setup. And to match the tremolo system, i found some anodized blue tuning machines (Sperzel)... I gave it a thought; when all this is done, the only original remaining part will be the neck plate and screws. And maybe the input jack (if i dont replace that too) and the tone pots...
As always: excuse the poor picture quality!
Cheers!
